  3. 溶氧感測器
  4. 溶氧感測器-序列埠監控視窗
溶氧感測器-序列埠監控視窗
已排程 已置頂 已鎖定 已移動 溶氧感測器
esp32溶氧感測器序列埠監控視窗
1 貼文 1 Posters 17 瀏覽
    2.溶氧感測器 序列埠監控視窗.pdf
    #define DO_PIN 36
    #define VREF 5000    //VREF (mv)
    #define ADC_RES 4096 //ADC Resolution
    //Single-point calibration Mode=0
    //Two-point calibration Mode=1
    #define TWO_POINT_CALIBRATION 0
    #define READ_TEMP (25) //Current water temperature ℃, Or temperature sensor function
    //Single point calibration needs to be filled CAL1_V and CAL1_T
    #define CAL1_V (1600) //mv
    #define CAL1_T (25)   //℃
    //Two-point calibration needs to be filled CAL2_V and CAL2_T
    //CAL1 High temperature point, CAL2 Low temperature point
    #define CAL2_V (1300) //mv
    #define CAL2_T (15)   //℃
    const uint16_t DO_Table[41] = {
        14460, 14220, 13820, 13440, 13090, 12740, 12420, 12110, 11810, 11530,
        11260, 11010, 10770, 10530, 10300, 10080, 9860, 9660, 9460, 9270,
        9080, 8900, 8730, 8570, 8410, 8250, 8110, 7960, 7820, 7690,
        7560, 7430, 7300, 7180, 7070, 6950, 6840, 6730, 6630, 6530, 6410};
    uint8_t Temperaturet;
    uint16_t ADC_Raw;
    uint16_t ADC_Voltage;
    uint16_t DO;
    int16_t readDO(uint32_t voltage_mv, uint8_t temperature_c)
    #if TWO_POINT_CALIBRATION == 0
      uint16_t V_saturation = (uint32_t)CAL1_V + (uint32_t)35 * temperature_c - (uint32_t)CAL1_T * 35;
      return (voltage_mv * DO_Table[temperature_c] / V_saturation);
    #else
      uint16_t V_saturation = (int16_t)((int8_t)temperature_c - CAL2_T) * ((uint16_t)CAL1_V - CAL2_V) / ((uint8_t)CAL1_T - CAL2_T) + CAL2_V;
    #endif
    double DOSensor;
    void setup()
      Serial.begin(115200);
    void loop()
      Temperaturet = (uint8_t)READ_TEMP;
      ADC_Raw = analogRead(DO_PIN);
      ADC_Voltage = uint32_t(VREF) * ADC_Raw / ADC_RES;
      DOSensor = ((double)(readDO(ADC_Voltage, Temperaturet))/1000);
      Serial.print("Temperature:\t" + String(Temperaturet) + "\t");
      Serial.print("ADC RAW:\t" + String(ADC_Raw) + "\t");
      Serial.print("ADC Voltage:\t" + String(ADC_Voltage) + "\t");
      Serial.println("DO:\t" + String(readDO(ADC_Voltage, Temperaturet)) + "\t");
      Serial.print("目前溶氧:");
      Serial.println( String(DOSensor) + " mg/L");
      delay(1000);
