  3. AHT15溫濕度感測器
  4. AHT15-簡易藍芽傳輸
AHT15-簡易藍芽傳輸
已排程 已置頂 已鎖定 已移動 AHT15溫濕度感測器
esp32aht15溫濕度感測器藍芽傳輸
1 貼文 1 Posters 17 瀏覽
    ATH15溫濕度感測器_簡易藍牙傳輸_教案.pdf
    #include <Wire.h>
    #include <BluetoothSerial.h>  // 匯入藍牙序列通訊的函式庫
    #define AHT15_ADDRESS 0x38
    #define AHT15_RESET 0xBA
    #define AHT15_INIT 0xBE
    #define AHT15_START_MEASUREMENT 0xAC
    BluetoothSerial BT; // 宣告藍牙物件,名稱為BT
      Wire.begin();
      Serial.begin(115200);
      BT.begin("Denny0628"); // 請改名例如英文+ 生日
      // Reset sensor
      Wire.beginTransmission(AHT15_ADDRESS);
      Wire.write(AHT15_RESET);
      Wire.endTransmission();
      delay(20);
      // Initialize sensor
      Wire.write(AHT15_INIT);
      Wire.write(0x08);
      Wire.write(0x00);
      delay(10);
      // Start measurement
      Wire.write(AHT15_START_MEASUREMENT);
      Wire.write(0x33);
      Wire.write(0x00);
      delay(80);
      // Read data
      Wire.requestFrom(AHT15_ADDRESS, 6);
      uint8_t data[6];
      for (int i = 0; i < 6; i++) {
        data[i] = Wire.read();
      // Calculate humidity and temperature
      uint32_t rawHumidity = ((uint32_t)data[1] << 12) | ((uint32_t)data[2] << 4) | (data[3] >> 4);
      float humidity = rawHumidity * 100.0 / (1 << 20);
      uint32_t rawTemperature = (((uint32_t)data[3] & 0xF) << 16) | ((uint32_t)data[4] << 8) | data[5];
      float temperature = ((200.0 * rawTemperature) / (1 << 20)) - 50;
      // Print results in Serial Monitor
      Serial.print("Humidity: ");
      Serial.print(humidity);
      Serial.print("% , ");
      Serial.print("Temperature: ");
      Serial.print(temperature);
      Serial.println("°C");
      // 在藍牙上打印溫度和濕度
      BT.print(temperature); // 將溫度值透過藍牙傳輸
      BT.print("*C, ");
      BT.print(humidity);  // 將濕度值透過藍牙傳輸
      BT.println(" H");
      delay(2500);
