水位感測器-序列埠視窗監控
int water_sensor=36; // 水位感測器S信號腳 連接到ESP32的 GPIO36 int a; void setup() { Serial.begin(115200); pinMode(water_sensor,INPUT); //設置water_sensor對應的腳GPIO36為輸入 } void loop() { int val=analogRead(water_sensor); //從水位感測器讀出類比數值 a=map(val,0,4095,0,100); //將val轉換成百分比顯示 Serial.print("水位狀態:"); Serial.print(val); Serial.println(" val"); Serial.print("水位百分比:"); Serial.print(a); Serial.println(" %"); delay(1000); }
