  3. TDS Sensor水質硬度傳感器
  4. TDS Sensor水質硬度傳感器-NB-IoT
已排程 已置頂 已鎖定 已移動 TDS Sensor水質硬度傳感器
水質硬度傳感器tds sensornb-iotesp32
1 貼文 1 Posters 36 瀏覽
    4.TDS Sensor-NB-IoT.pdf
    #include <Wire.h>
    #include "MatrixInt.h" //安裝方式:https://www.nmking.io/index.php/2022/12/15/701/
    #define TdsSensorPin 33       //TDS感測器接入腳位GPIO 33
    #define VREF 3.3              // analog reference voltage(Volt) of the ADC
    #define SCOUNT  30            // sum of sample point
    int analogBuffer[SCOUNT];     // store the analog value in the array, read from ADC
    int analogBufferTemp[SCOUNT];
    int analogBufferIndex = 0;
    int copyIndex = 0;
    long WNB303Timeout = 10000; //返回0=Timeout
    int WNB303ResetPIN = 14;      //  設定 WNB303 重置腳位為輸出腳位
    int WNB303PowerPIN = 15;      //  設定 WNB303 電源控制腳位為輸出腳位
    float averageVoltage = 0;
    float tdsValue = 0;
    float temperature = 25;       // 設定當前環境溫度 (計算PPM需使用溫度資訊)
    // median filtering algorithm
    int getMedianNum(int bArray[], int iFilterLen){
      int bTab[iFilterLen];
      for (byte i = 0; i<iFilterLen; i++)
      bTab[i] = bArray[i];
      int i, j, bTemp;
      for (j = 0; j < iFilterLen - 1; j++) {
        for (i = 0; i < iFilterLen - j - 1; i++) {
          if (bTab[i] > bTab[i + 1]) {
            bTemp = bTab[i];
            bTab[i] = bTab[i + 1];
            bTab[i + 1] = bTemp;
      if ((iFilterLen & 1) > 0){
        bTemp = bTab[(iFilterLen - 1) / 2];
        bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
      return bTemp;
    String MQTTServer = "mqttgo.io";//免註冊MQTT伺服器
    String MQTTPort = "1883";//MQTT Port
    String MQTTUser = "";//不須帳密
    String MQTTPassword = "";//不須帳密
    //推播主題1:推播PPM(記得改Topic)
    String MQTTPubTopic = "YourTopic/class/TDSPPM";
    long MQTTLastPublishTime = 0;//此變數用來記錄推播時間
    long MQTTPublishInterval = 5000;//每5秒推撥一次
      Serial.begin(115200);       //  設定序列埠監控視窗的鮑率
      Serial2.begin(115200);      //  設定 WNB303 的鮑率
      Wire.begin(26, 27);         //  Matrix I2C
      for (int i = 0; i <= 7; ++i) MatrixInt(i, 0);//關閉所有燈號
      pinMode(TdsSensorPin,INPUT);
      pinMode(WNB303ResetPIN, OUTPUT);        //  設定 WNB303 電源控制腳位為輸出腳位
      pinMode(WNB303PowerPIN, OUTPUT);        //  設定 WNB303 重置腳位為輸出腳位
      delay(1000);
      Serial.println("\r\n\r\n======================\r\nSystem Starting....");
      String result = "";
      //  開啟 Modem 的電源,開啟關閉之間須間隔10秒(延時電路)
      WNB303Restart(10);
      //檢查網路註冊狀態,5分鐘內無法註冊,則重新啟動WNB303
      int tryCount = 0;
      while (1) {
        boolean resultb = WNB303CheckReg();
        Serial.print("WNB303CheckNetReg result="); Serial.println(resultb);
        if (resultb == false) {
          Serial.println("時間內無法註冊網路(" + String(tryCount) + ")");
          delay(10000);
        else break;
        if (tryCount++ >= 30) { //無法註冊已經超過5分鐘
          tryCount = 0;
          WNB303Restart(30);
      //檢查網路訊號品質
      result = WNB303CheckRSSI();
      Serial.print("WNB303CheckRSSI result="); Serial.println(result);
      delay(10000);
      ReadPPM();
      //檢查時間,傳輸步驟:檢查網路、讀取距離、MQTT連線、推播、關閉
        MatrixInt(7, 1);
        //沒有網路,則重新啟動WNB303
        String result = "";
        //檢查網路狀態
        if (!(WNB303CheckReg())) {
          WNB303Restart(60); //60秒後重新檢測網路
          return;
        }else result = WNB303CheckRSSI();
        //連線mqtt
        result = mqttConnect(MQTTServer, MQTTPort, MQTTUser, MQTTPassword);
        if (result == "OK") Serial.println("MQTT Connected");
        ReadPPM();
        byte tds1 = 0;
        tds1 = tdsValue,0;
         String payload = String((int)tds1);
        //推播訊息
        result = mqttPublish(MQTTPubTopic, "0", "0", "0", payload);
        if (result == "OK") Serial.println("Data:\"" + payload + "\" Published to " + MQTTPubTopic);
        //關閉mqtt
        result = mqttDisconnect();
        if (result == "OK") Serial.println("MQTT Disconnected");
        MatrixInt(7, 0);
      delay(1000);
    void ReadPPM() {
      static unsigned long analogSampleTimepoint = millis();
      if(millis()-analogSampleTimepoint > 40U){     //every 40 milliseconds,read the analog value from the ADC
        analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin);    //read the analog value and store into the buffer
        analogBufferIndex++;
        if(analogBufferIndex == SCOUNT){
      static unsigned long printTimepoint = millis();
      if(millis()-printTimepoint > 800U){
        for(copyIndex=0; copyIndex<SCOUNT; copyIndex++){
          analogBufferTemp[copyIndex] = analogBuffer[copyIndex];
          // read the analog value more stable by the median filtering algorithm, and convert to voltage value
          averageVoltage = getMedianNum(analogBufferTemp,SCOUNT) * (float)VREF / 4096.0;
          //temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.02*(fTP-25.0));
          float compensationCoefficient = 1.0+0.02*(temperature-25.0);
          float compensationVoltage=averageVoltage/compensationCoefficient;
          //convert voltage value to tds value
          tdsValue=(133.42*compensationVoltage*compensationVoltage*compensationVoltage - 255.86*compensationVoltage*compensationVoltage + 857.39*compensationVoltage)*0.5;
          //Serial.print("voltage:");
          //Serial.print(averageVoltage,2);
          //Serial.print("V   ");
          Serial.print("TDS Value:");
          Serial.print(tdsValue,0);
          Serial.println("ppm");
    //連線mqtt
    String mqttConnect(String Host, String Port, String MQTTUser, String MQTTPassword) {
      //1.取得IP
      String result = "" ;
      String IP = AT2WNB303("AT+EDNS=\"" + Host + "\"", "+EDNS:");
      IP.trim(); IP = split( IP, ':', 1);
      if (IP.length() <= 7) return "Error: Can't Get IP";
      //2.建立連線
      result = AT2WNB303("AT+EMQNEW=\"" + IP + "\",\"" + Port + "\"" + "," + 60000  + "," + 1024, "+EMQNEW:");
      String mqttid = split( result, ':', 1);
      //Serial.print("MQTTCreate result="); Serial.println(mqttid);
      //以亂數為ClientID
      String  MQTTClientid = "NBIoT-" + String(random(1000000, 9999999));
      result = AT2WNB303("AT+EMQCON=" + mqttid + ",3,\"" + MQTTClientid + "\"" + "," + 60000  + ",0,0,\"" + MQTTUser + "\",\"" + MQTTPassword + "\"", "OK");
      //Serial.print("MQTTConnect result="); Serial.println(result);
      return result;
    //推播訊息
    String mqttPublish(String Topic, String QoS, String retained, String dup , String Payload) {
      String hexPayload = Str2Hex(Payload);
      String lenHexPayload = String(hexPayload.length());
      result = AT2WNB303("AT+EMQPUB=0," + Topic + "," + QoS + "," + retained + "," + dup + "," + lenHexPayload + "," + hexPayload, "OK");
      return result;
    //關閉mqtt連線
    String mqttDisconnect() {
      result = AT2WNB303("AT+EMQDISCON=0", "OK");
      return result;
    //檢查網路註冊狀態 return true or false
    boolean WNB303CheckReg() {
      String result = "";
      boolean CEREG = false;
      result = AT2WNB303("AT+CEREG?", "+CEREG:");
      if (result.indexOf("0,1") >= 0 || result.indexOf("1,1") >= 0) { //註冊成功
        MatrixInt(5, 0);//亮紅燈
        MatrixInt(6, 1);//亮綠燈
        CEREG = true;
        MatrixInt(5, 1);//亮紅燈
        MatrixInt(6, 0);//亮綠燈
        CEREG = false;
      return CEREG;
    //檢查網路訊號品質 return RSSI,當RSSI=0或99代表沒訊號
    int WNB303CheckRSSI() {
      String result = "";
      int RSSI = 0;
      result = AT2WNB303("AT+CESQ", "+CESQ:");
      //處理+CESQ:
      if (!(result == "-1")) {
        int CESQ = split(split(result, ':', 1), ',', 0).toInt();
        RSSI = CESQ - 111;
      if (RSSI == -111 || RSSI == 210) RSSI = 0;
      MatrixLEDrssi(RSSI);
      return RSSI;
    //重新啟動WNB303(單位為秒)
    void WNB303Restart(int dalayTime) {
      AT2WNB303("POWEROFF", "");
      AT2WNB303("POWERON", "");
      delay(dalayTime * 1000) ;
    //HTTP GET
    String HTTPGET(String Protocol, String Host, String port, String Url) {
      //例如 http://x.x.x.x/update?api_key=xxxxx&field1=60
      //拆解成Protocol="http" host="x.x.x.x" port="80" Url="/update?api_key=CxxxxxxJ&field1=60"
      //1.轉換網址IP
      //2.建立連線
      String PIP = Protocol + "://" + IP + ":" + port + "/";
      int PIPlen = PIP.length();
      //Serial.println("PIP=" + PIP + ",len=" + String(PIPlen));
      result = AT2WNB303("AT+EHTTPCREATE=0," + String(PIPlen) + "," + String(PIPlen) + ",\"" + PIP + "\"", "+EHTTPCREAT");
      result.trim(); String clientid = split(result, ':', 1);
      if (result == "") return "Error: Can't Create Connection";
        //3.開啟連線
        result = AT2WNB303("AT+EHTTPCON=" + clientid, "OK");
        result.trim();
        if (!(result == "OK")) result = "Error: Can't Connect to Server";
        //4.組成網址並傳送
        int LenUrl = Url.length();
        Url = clientid + ",0," + String(LenUrl) + "," + Url + ",0,,0,,0,";
        Url = "0," + String(Url.length()) + "," + String(Url.length()) + "," + Url;
        result = AT2WNB303("AT+EHTTPSEND=" + Url, "OK");
        if (!(result == "OK")) result = "Error: Can't Send to Server";
      delay(1000);
      //關閉連線
      AT2WNB303("AT+EHTTPDISCON=" + clientid, "OK");
      //Serial.println(result);
      delay(1000);
      AT2WNB303("AT+EHTTPDESTROY=" + clientid, "OK");
      delay(1000);
      return result;
    //HTTP POST
    String HTTPPOST(String Protocol, String Host, String port, String Url , String contType , String Data) {
      //1.轉換網址IP
      //2.建立連線
        //3.開啟連線
        result.trim();
        //4.組成網址並傳送
        int i = 0;
        String PostCommand[10];
        PostCommand[i++] = clientid + ",1," + Url.length() + "," + Url + ",0,," + contType.length() + "," + contType + ",";
        //Serial.println("command1=" + PostCommand[i - 1]);
        String hexData = Str2Hex(Data);
        int lenHexData = hexData.length();
        PostCommand[i++] = String(lenHexData) + ",";
        //Serial.println("command2=" + PostCommand[i - 1]);
        int num = 30;
        for (int n = 0; n < lenHexData; n = n + num) {
          String DataSend = "";
          if (n + num < lenHexData) {
            //切割字串
            DataSend = hexData.substring(n, n + num);
          } else if (lenHexData % num > 0) {
            int remainder = lenHexData % num;
            //切割字串
            DataSend = hexData.substring(n, n + remainder);
          PostCommand[i++] = DataSend;
        //求出每條命令長度
        int totalLenHexData = 0;
        for (int j = 0; j <= i - 1; j++) {
          totalLenHexData = totalLenHexData + PostCommand[j].length();
          PostCommand[j] = String(PostCommand[j].length()) + "," + PostCommand[j];
        //完成命令組合
          if (j == 1) PostCommand[j] = "AT+EHTTPSEND=1," + String(totalLenHexData) + "," + PostCommand[j];
          else if (j == i - 1) PostCommand[j] = "AT+EHTTPSEND=0," + String(totalLenHexData) + "," + PostCommand[j];
          else PostCommand[j] = "AT+EHTTPSEND=1," + String(totalLenHexData) + "," + PostCommand[j];
          result = AT2WNB303(PostCommand[j], "OK");
          //Serial.println("POST" + String(j) + + ":" + result);
      delay(1000);
      //關閉連線
      delay(1000);
      delay(1000);
      return result;
    //將訊息傳到WNB303,並讀取回傳訊息 0代表timeout
    String AT2WNB303(String ATdata, String StartWith) {
      Serial.println("你的命令是:" + ATdata);
      if (ATdata.length() > 0) { //送出AT命令
        ATdata.trim();
        String command = ATdata;
        command.toUpperCase();
        if (command == "RESET") {  //重置 WNB303
          digitalWrite(WNB303ResetPIN, HIGH);
          delay(10000);
          digitalWrite(WNB303ResetPIN, LOW);
          return "RESET OK";
        else if (command == "POWERON") {  //開啟 WNB303 的電源
          digitalWrite(WNB303PowerPIN, HIGH);
          return "POWERON OK";
        else if (command == "POWEROFF") {  //關閉 WNB303 的電源
          digitalWrite(WNB303PowerPIN, LOW);
          return "POWEROFF OK";
        else  {  //送出AT命令
          Serial2.println(ATdata);
      else return "";
      String result = "";
      //等候回應資料
      long StartTime = millis();
      while (1) {
        result = "";
        while (Serial2.available()) { //WNB303有資料回傳
          char c = Serial2.read();    //從WNB303讀取一個位元組
          result += c;                //將讀到的字元 c 加進字串 Xfer
          if (c == '\n') break;
        result.trim();
        if (result.startsWith(StartWith)) break; //結尾OK返回
        if ((millis() - StartTime) >= WNB303Timeout ) { //Timeout返回
          result = "0";
          break;
      return result;
    //字串轉HEX
    String Str2Hex(String msg) {
      String a = "";
      for (int i = 0; i < msg.length(); i++)  {
        a = a + String(msg.charAt(i), HEX);
      return a;
    //HEX轉字串
    String Hex2Str(String msg) {
      char input[msg.length() + 1];
      msg.toCharArray(input, msg.length() + 1);
      char c[sizeof(input)];
      String a = "";
      for (int i = 0; i < sizeof(input) - 1; i += 2) {
        char temp[3];
        temp[0] = input[i];
        temp[1] = input[i + 1];
        int val = ASCIIHexToInt(temp[0]) * 16 + ASCIIHexToInt(temp[1]);
        c[i] = toascii(val);
        a = a + String(c[i]);
      return a;
    //ASC轉INT
    int ASCIIHexToInt(char c) {
      int ret = 0;
      if ((c >= '0') && (c <= '9')) ret = (ret << 4) + c - '0';
      else ret = (ret << 4) + toupper(c) - 'A' + 10;
      return ret;
    //split拆解,範例:String a1=split(“aa,bb,cc”,’,’,0);
    String split(String data, char separator, int index) {
      int found = 0;
      int strIndex[] = { 0, -1 };
      int maxIndex = data.length() - 1;
      for (int i = 0; i <= maxIndex && found <= index; i++) {
        if (data.charAt(i) == separator || i == maxIndex) {
          found++;
          strIndex[0] = strIndex[1] + 1;
          strIndex[1] = (i == maxIndex) ? i + 1 : i;
      return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
