  3. TDS Sensor水質硬度傳感器
  4. TDS Sensor水質硬度傳感器-序列埠視窗監控
已排程 已置頂 已鎖定 已移動 TDS Sensor水質硬度傳感器
tds sensor水質硬度傳感器序列埠視窗監控esp32
1 貼文 1 Posters 16 瀏覽
    1.TDS Sensor-序列埠視窗監控.pdf
    // Original source code: https://wiki.keyestudio.com/KS0429_keyestudio_TDS_Meter_V1.0#Test_Code
    // Project details: https://RandomNerdTutorials.com/esp32-tds-water-quality-sensor/
    #define TdsSensorPin 33       //TDS感測器腳位
    #define VREF 3.3              // analog reference voltage(Volt) of the ADC
    #define SCOUNT  30            // sum of sample point
    int analogBuffer[SCOUNT];     // store the analog value in the array, read from ADC
    int analogBufferTemp[SCOUNT];
    int analogBufferIndex = 0;
    int copyIndex = 0;
    float averageVoltage = 0;
    float tdsValue = 0;
    float temperature = 25;       // 當前環境溫度
    // median filtering algorithm
    int getMedianNum(int bArray[], int iFilterLen){
      int bTab[iFilterLen];
      for (byte i = 0; i<iFilterLen; i++)
      bTab[i] = bArray[i];
      int i, j, bTemp;
      for (j = 0; j < iFilterLen - 1; j++) {
        for (i = 0; i < iFilterLen - j - 1; i++) {
          if (bTab[i] > bTab[i + 1]) {
            bTemp = bTab[i];
            bTab[i] = bTab[i + 1];
            bTab[i + 1] = bTemp;
      if ((iFilterLen & 1) > 0){
        bTemp = bTab[(iFilterLen - 1) / 2];
        bTemp = (bTab[iFilterLen / 2] + bTab[iFilterLen / 2 - 1]) / 2;
      return bTemp;
    void setup(){
      Serial.begin(115200);
      pinMode(TdsSensorPin,INPUT);
    void loop(){
      static unsigned long analogSampleTimepoint = millis();
      if(millis()-analogSampleTimepoint > 40U){     //every 40 milliseconds,read the analog value from the ADC
        analogBuffer[analogBufferIndex] = analogRead(TdsSensorPin);    //read the analog value and store into the buffer
        analogBufferIndex++;
        if(analogBufferIndex == SCOUNT){
      static unsigned long printTimepoint = millis();
      if(millis()-printTimepoint > 800U){
        for(copyIndex=0; copyIndex<SCOUNT; copyIndex++){
          analogBufferTemp[copyIndex] = analogBuffer[copyIndex];
          // read the analog value more stable by the median filtering algorithm, and convert to voltage value
          averageVoltage = getMedianNum(analogBufferTemp,SCOUNT) * (float)VREF / 4096.0;
          //temperature compensation formula: fFinalResult(25^C) = fFinalResult(current)/(1.0+0.02*(fTP-25.0));
          float compensationCoefficient = 1.0+0.02*(temperature-25.0);
          float compensationVoltage=averageVoltage/compensationCoefficient;
          //convert voltage value to tds value
          tdsValue=(133.42*compensationVoltage*compensationVoltage*compensationVoltage - 255.86*compensationVoltage*compensationVoltage + 857.39*compensationVoltage)*0.5;
          //Serial.print("voltage:");
          //Serial.print(averageVoltage,2);
          //Serial.print("V   ");
          Serial.print("TDS Value:");
          Serial.print(tdsValue,0);
          Serial.println("ppm");
